跳转到主内容
HP Chromebook 14-ak013dx Keyboard Replacement
你所需要的
  1. HP Chromebook 14-ak013dx Keyboard Replacement, Opening the Case: 步骤 1 中的图像 1,3 HP Chromebook 14-ak013dx Keyboard Replacement, Opening the Case: 步骤 1 中的图像 2,3 HP Chromebook 14-ak013dx Keyboard Replacement, Opening the Case: 步骤 1 中的图像 3,3
    • Using a p01 screwdriver bit, unscrew the 13 screws on the back of the laptop (two will be under the rubber footpads)
    • Flip to laptop over and raise the screen. You will need to use a tool to "pop" the keyboard off, slowly sliding the tool along the outside
  2. HP Chromebook 14-ak013dx Keyboard Replacement, Removing the keyboard from the Motherboard: 步骤 2 中的图像 1,3 HP Chromebook 14-ak013dx Keyboard Replacement, Removing the keyboard from the Motherboard: 步骤 2 中的图像 2,3 HP Chromebook 14-ak013dx Keyboard Replacement, Removing the keyboard from the Motherboard: 步骤 2 中的图像 3,3
    • Carefully raise the keyboard off the body of the laptop
    • Locate two ribbons connecting the keyboard to the motherboard
    • Gently flip up the bars holding the ribbons in place, and remove the ribbon
  3. HP Chromebook 14-ak013dx Keyboard Replacement, Remove the Touchpad from the Keyboard: 步骤 3 中的图像 1,3 HP Chromebook 14-ak013dx Keyboard Replacement, Remove the Touchpad from the Keyboard: 步骤 3 中的图像 2,3 HP Chromebook 14-ak013dx Keyboard Replacement, Remove the Touchpad from the Keyboard: 步骤 3 中的图像 3,3
    • Separate the keyboard from the body of the laptop
    • Using a p001 screwdriver, remove the two screws holding the touchpad in place
    • Gently lift the bar holding the ribbon in place, and remove the ribbon
  4. HP Chromebook 14-ak013dx Keyboard Replacement, Separate the Keyboard and Touchpad: 步骤 4 中的图像 1,2 HP Chromebook 14-ak013dx Keyboard Replacement, Separate the Keyboard and Touchpad: 步骤 4 中的图像 2,2
    • Carefully push on the 'knob' on the touchpad; the touchpad will fall out of the keyboard
    • Carefully store the touchpad separately from the keyboard if not immediately replacing the keyboard
结论
To reassemble your device, follow these instructions in reverse order. Add the old touchpad to the new keyboard, and be careful reattaching all ribbons. Keyboard should 'snap' into place before put screws back on the body.
团队
dwsad dwsad 的会员
Community
1 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 102
