跳转到主内容
HP Chromebook 14-ak013dx Internal Speaker Replacement
你所需要的
  1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: 步骤 1 中的图像 1,3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: 步骤 1 中的图像 2,3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: 步骤 1 中的图像 3,3
    • Starting with the laptop on its back, remove the 13 screws holding the keyboard in place with a P00 screwdriver (2 screws are hidden behind the rubber footers)
    • Open the screen, revealing the keyboard. Using a prying tool, 'pop' the keyboard out by sliding the tool around the edge
  2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: 步骤 2 中的图像 1,3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: 步骤 2 中的图像 2,3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: 步骤 2 中的图像 3,3
    • Gently raise the keyboard from the body, careful not to rip out the ribbons
    • With light pressure, flip the black bar holding the ribbons in place, and remove the ribbons from the body
  3. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Keyboard: 步骤 3 中的图像 1,1
    • Completely remove the keyboard, place away from the body of the laptop
  4. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: 步骤 4 中的图像 1,3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: 步骤 4 中的图像 2,3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: 步骤 4 中的图像 3,3
    • With a P00 Screwdriver, remove the 9 screws holding the battery in place
    • Gently pry the cable connecting the battery to the motherboard off
    • Battery will lift away from the body (screen will now be heavier than the body, be careful not to drop it)
  5. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: 步骤 5 中的图像 1,2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: 步骤 5 中的图像 2,2
    • Gently disconnect the cable connecting the internal speaker to the motherboard
    • Using a P00 Screwdriver, remove the final screw from the left speaker
    • Using a prying tool, carefully remove the speaker out of the body
  6. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: 步骤 6 中的图像 1,2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: 步骤 6 中的图像 2,2
    • With a P00 Screwdriver, remove the final screw from the right speaker
    • Carefully remove the right internal speaker from the body
    • The entire speaker (barring some tape you may need to remove) should lift away from the body of the laptop
结论
另外一个人完成了本指南。
团队
dwsad dwsad 的会员
Community
1 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 71
