跳转到主内容
HP Chromebook 14-ak013dx Charging Port Replacement
你所需要的
  1. HP Chromebook 14-ak013dx Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,3 HP Chromebook 14-ak013dx Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,3 HP Chromebook 14-ak013dx Charging Port Replacement, Charging Port: 步骤 1 中的图像 3,3
    • Position the laptop so that the bottom is facing towards you and the fold facing away.
    • Using a plastic opening tool or another prying device, remove the five rubber stoppers on the upper side of the laptop to reveal screws.
    • Using a Phillips-head screwdriver or another capable tool, unscrew the thirteen 5.0 mm Phillips #1 screws on the base of the laptop.
  2. HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 2 中的图像 1,2 HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 2 中的图像 2,2
    • Flip the laptop over and open it so the keyboard is visible.
    • Using a plastic opening or prying tool, insert the tool between the keyboard and bottom casing. Then rotate the tool away from the laptop to open it up.
    • Be sure not to pull the keyboard away just yet as the ribbons are still connected.
  3. HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 3 中的图像 1,3 HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 3 中的图像 2,3 HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 3 中的图像 3,3
    • Using a plastic opening tool or your fingers, lift the two black flaps that hold the ribbons connecting the keyboard and touch-pad to fully disconnect the keyboard from the laptop.
    • Disconnect the battery cable from the system board
  4. HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 5 中的图像 1,3 HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 5 中的图像 2,3 HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 5 中的图像 3,3
    • Partially remove the tape that is covering the two wires connecting to the wireless adaptor.
    • Disconnect the white and black wires from the adaptor and remove it from the plastic piece used to guide the wire to free up space.
    • The wires are labeled (1) and (2), make note of their position for reassembly
  5. HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 6 中的图像 1,3 HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 6 中的图像 2,3 HP Chromebook 14-ak013dx Charging Port Replacement: 步骤 6 中的图像 3,3
    • Using a prying tool or your fingers, remove the charging port head.
    • Pull by the white plastic or by the wiring away from the connector to remove the piece completely.
    • Replace the broken charging port with a new one.
结论
5等其他人完成本指南。
Igli Duro
于02/15/17注册
200 声望
撰写一个指南
团队
USF Tampa, Team 10-2, Remmell Spring 2017 USF Tampa, Team 10-2, Remmell Spring 2017 的会员
USFT-REMMELL-S17S10G2
4 名成员
创作了1篇指南
2条评论
Where can you find a replacement charger port? My model is HP chromebook 11 g5ee
Neah McGovern - 回复
Worked! THANK YOU!
RACHEL LICATA - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 5,741
