跳转到主内容
HP Chromebook 14-ak013dx WiFi Card Replacement
你所需要的
  1. HP Chromebook 14-ak013dx  WiFi Card Replacement, WiFi Card: 步骤 1 中的图像 1,3 HP Chromebook 14-ak013dx  WiFi Card Replacement, WiFi Card: 步骤 1 中的图像 2,3 HP Chromebook 14-ak013dx  WiFi Card Replacement, WiFi Card: 步骤 1 中的图像 3,3
    • Turn the Chromebook upside down, as shown in the first image.
    • Remove the five rubber feet pieces as shown using a spudger.
    • Proceed to remove all exposed 4.2 mm Phillips #1 screws on the bottom of the Chromebook.
  2. HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 2 中的图像 1,3 HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 2 中的图像 2,3 HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool to split the back panel from the keyboard.
    • Move the opening tool around the sides of the back panel to detach it. Do not fully remove the panel, taking note of the two ribbon cables.
  3. HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 3 中的图像 1,3 HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 3 中的图像 2,3 HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 3 中的图像 3,3
    • Remove both ribbon cables attaching the separated keyboard to the motherboard.
    • The large black ribbon cable was a tab that should be pried open to loosen the ribbon from its hub. Use the plastic opening tool as shown.
    • Gently pull out the short white ribbon cable out of its hub.
  4. HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 4 中的图像 1,3 HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 4 中的图像 2,3 HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 4 中的图像 3,3
    • Disconnect the battery cable shown in the first picture before moving on. This can be done with an opening tool if necessary.
  5. HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 5 中的图像 1,3 HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 5 中的图像 2,3 HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 5 中的图像 3,3
    • Remove the piece of tape from the top of the Wi-Fi card.
    • Also, unhook the two cables from the card by lifting on the connectors.
    • Remove the single M2XL3 screw from the Wi-Fi card using a Phillips #1 screwdriver.
  6. HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 6 中的图像 1,2 HP Chromebook 14-ak013dx  WiFi Card Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to remove the card from the board. The card is now free to be taken out.
结论
另外一个人完成了本指南。
团队
IUPUI, Team S3-G5, Harley Fall 2018 IUPUI, Team S3-G5, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S3G5
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,676
