跳转到主内容
加入维修社区 - 创建账户
HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement
你所需要的
  1. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement, Keyboard and Touchpad: 步骤 1 中的图像 1,2 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement, Keyboard and Touchpad: 步骤 1 中的图像 2,2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    询问修复机器人
    添加评论
  2. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 步骤 2 中的图像 1,3 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 步骤 2 中的图像 2,3 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 步骤 2 中的图像 3,3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    询问修复机器人
    添加评论
  3. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 步骤 3 中的图像 1,3 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 步骤 3 中的图像 2,3 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 步骤 3 中的图像 3,3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    询问修复机器人
    添加评论
  4. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 步骤 4 中的图像 1,1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    询问修复机器人
    添加评论
  5. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 步骤 5 中的图像 1,1
    • Set aside the detached keyboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
17等其他人完成本指南。
团队
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 的会员
USFT-WATKINS-W15S17G2
4 名成员
创作了8篇指南
10指南评论
In the black variant of this model I found that there are two screws under the rubber feet near the hinge.
Justin Cowen - 回复 分享
Super easy repair, keep track of your screws and be very careful with ribbon that connects keyboard and Touch pad.
Terry - 回复 分享
This was very close to a similar HP Chromebook I had to repair recently. Such a beautiful and simple process. I cleaned the keyboard connectors and everything functioned perfectly after I was done. The whole process took about 30 minutes (allotting 10 minutes to find my rubbing alcohol that my wife hid from me).
Josh Bollman - 回复 分享
Any idea how to get the replacement keyboard?
Pawel Wozniak - 回复 分享
At the top of this page under "Relevant parts" there is a link to purchase the keyboard replacement.
Kevin Piper - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 58
总计 16,808
