跳转到主内容
HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement
你所需要的
  1. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Keyboard and Touchpad: 步骤 1 中的图像 1,2 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Keyboard and Touchpad: 步骤 1 中的图像 2,2
    • Flip the laptop with the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew these screws.
  2. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 2 中的图像 1,3 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 2 中的图像 2,3 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 2 中的图像 3,3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 3 中的图像 1,3 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 3 中的图像 2,3 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 3 中的图像 3,3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 4 中的图像 1,1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Set aside the detached keyboard.
  6. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Bluetooth and Wireless Card: 步骤 6 中的图像 1,2 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Bluetooth and Wireless Card: 步骤 6 中的图像 2,2
    • Using a spudger, remove the white and black cables from the card.
  7. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 7 中的图像 1,2 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 7 中的图像 2,2
    • Remove screw from card.
  8. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 步骤 8 中的图像 1,1
    • Gently pull card at a 45° angle to remove it.
结论
另外一个人完成了本指南。
Kevin Piper
于01/16/15注册
1,599 声望
创作了6篇指南
团队
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 的会员
USFT-WATKINS-W15S17G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 1,704
