跳转到主内容
HP Chromebook 14 G5 Wi-Fi Card Replacement
你所需要的
  1. HP Chromebook 14 G5 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 1,2 HP Chromebook 14 G5 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 2,2
    • Use a spudger to remove four rubber feet from the corners of the laptop.
    • Use a spudger to remove seven silicone covers.
  2. HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Remove the 11 screws from the bottom panel using a Phillips #1 screwdriver.
  3. HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Flip the laptop over and open up the display.
    • Using a opening pick, carefully separate the top housing from the bottom housing by working your way around the perimeter of the laptop and prying it open.
  4. HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Peel back the black tape covering the battery connector.
    • Using the spudger, unplug the battery connector from the motherboard.
  5. HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 5 中的图像 1,2 HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the keyboard ribbon lock with the spudger and disconnect the keyboard ribbon cable from the motherboard.
  6. HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 6 中的图像 1,2 HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 6 中的图像 2,2
    • Carefully lift the touch pad ribbon lock with the spudger and disconnect the touch pad ribbon cable from the motherboard.
    • Remove the keyboard assembly from the device housing.
  7. HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 7 中的图像 1,2 HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 7 中的图像 2,2
    • Using the spudger, disconnect the two antennas from the Wi-Fi card.
  8. HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 8 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the screw securing the Wi-Fi card.
  9. HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 9 中的图像 1,2 HP Chromebook 14 G5 Wi-Fi Card Replacement: 步骤 9 中的图像 2,2
    • Gently remove the Wi-Fi card.
结论
Ethan Tran
于10/24/23注册
169 声望
撰写一个指南
团队
CSU Los Angeles, Team 13-1, Ribeiro Fall 2023 CSU Los Angeles, Team 13-1, Ribeiro Fall 2023 的会员
CSULA-RIBEIRO-F23S13G1
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 93
