跳转到主内容
HP Chromebook 14 G3 Battery Replacement
你所需要的
  1. HP Chromebook 14 G3 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the battery is completely drained before performing this repair. Failure can result in an electrical shock which may cause bodily harm.
    • Close the computer and flip it to its backside.
  2. HP Chromebook 14 G3 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the three screws from the middle row using a Phillips screwdriver.
  3. HP Chromebook 14 G3 Battery Replacement: 步骤 3 中的图像 1,1
    • Flip the computer once again and open the lid.
  4. HP Chromebook 14 G3 Battery Replacement: 步骤 4 中的图像 1,1
    • Insert a Jimmy into the space between the frame and the plastic cover and lift gently so that the cover begins to pop up.
    • Do this all around the frame until the entire frame is loose.
  5. HP Chromebook 14 G3 Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the cover up gently.
    • This cover has wires and plugs attached to it so pull the cover up slowly.
  6. HP Chromebook 14 G3 Battery Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • With one hand, hold the cover in a way that you can see inside, and with the other, use tweezers and disconnect the large ribbon wire by loosening the black lock and pulling on it until it is loose.
    • Do not perform these steps in a rush because these are very delicate wires. You may break or damage a wire or break a lock if you aren’t careful.
  7. HP Chromebook 14 G3 Battery Replacement: 步骤 7 中的图像 1,1
    • Use tweezers to disconnect the small ribbon wire by loosening the black lock and pulling on it until it is loose.
    • A light source is recommended to ensure that you remove it correctly.
    • Remove the frame from the laptop.
  8. HP Chromebook 14 G3 Battery Replacement: 步骤 8 中的图像 1,2 HP Chromebook 14 G3 Battery Replacement: 步骤 8 中的图像 2,2
    • Use tweezers to carefully detach the battery's cable connector from the motherboard.
    • Remove the screws holding the battery in place using a Phillips screwdriver.
    • Remove the battery.
结论
JesusMOjeda
于10/24/23注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team 13-8, Ribeiro Fall 2023 CSU Los Angeles, Team 13-8, Ribeiro Fall 2023 的会员
CSULA-RIBEIRO-F23S13G8
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 108
