跳转到主内容
HP Chromebook 11A G8 EE Wi-Fi Card Replacement
你所需要的
  1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: 步骤 1 中的图像 1,2 HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: 步骤 1 中的图像 2,2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using your tweezers, unplug the battery connector from the motherboard.
  5. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 5 中的图像 1,3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 5 中的图像 2,3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 5 中的图像 3,3
    • Using your tweezers, peel back the clear sheet covering the Wi-Fi card.
    • Using a Phillips #0 screwdriver, remove the screw securing the Wi-Fi card cover.
    • Using your tweezers, remove the cover.
  6. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 6 中的图像 1,2 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: 步骤 6 中的图像 2,2
    • Using your tweezers, unsnap the the coaxial antenna cables from the Wi-Fi Card.
    • Slide the Wi-Fi card out.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 35
总计 686
