跳转到主内容
HP Chromebook 11A G8 EE Screen Replacement
你所需要的
  1. HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: 步骤 1 中的图像 1,2 HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: 步骤 1 中的图像 2,2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Screen Replacement: 步骤 2 中的图像 1,3 HP Chromebook 11A G8 EE Screen Replacement: 步骤 2 中的图像 2,3 HP Chromebook 11A G8 EE Screen Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Screen Replacement: 步骤 3 中的图像 1,2 HP Chromebook 11A G8 EE Screen Replacement: 步骤 3 中的图像 2,2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Screen Replacement, Bezel: 步骤 4 中的图像 1,1
    • Pry the hinge cap off with your hands by lifting it up.
  5. HP Chromebook 11A G8 EE Screen Replacement: 步骤 5 中的图像 1,1
    • Use the iFixit opening tool to pry the bezel up.
  6. HP Chromebook 11A G8 EE Screen Replacement: 步骤 6 中的图像 1,1
    • Once you have pried away the bezel, pull it up towards you.
    • Peel it off gently from the screen.
  7. HP Chromebook 11A G8 EE Screen Replacement: 步骤 7 中的图像 1,1
    • You are finished once the bezel is off of the device.
  8. HP Chromebook 11A G8 EE Screen Replacement, Screen: 步骤 8 中的图像 1,1
    • Remove the four 3.5 mm screws with the Phillips #0 screwdriver.
  9. HP Chromebook 11A G8 EE Screen Replacement: 步骤 9 中的图像 1,1
    • Flip the screen towards you.
  10. HP Chromebook 11A G8 EE Screen Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Once the screen is flipped down, use the tweezers to peel away the black tape holding down the connector.
  11. HP Chromebook 11A G8 EE Screen Replacement: 步骤 11 中的图像 1,1
    • Next, peel away the tan tape, using the tweezers, exposing the screen connector.
  12. HP Chromebook 11A G8 EE Screen Replacement: 步骤 12 中的图像 1,1
    • Using the tweezers, remove the connector by the latch attached to it.
  13. HP Chromebook 11A G8 EE Screen Replacement: 步骤 13 中的图像 1,1
    • Finally, pull away the screen, to remove it from the device.
结论
8等其他人完成本指南。
Kim Travers
于09/03/21注册
523 声望
创作了2篇指南
一条评论
Does IFixit Sell this screen? I am unable to source parts and this screen for these educational units by HP. I wish iFixit would also list the parts that are needed for the repairs and not just the tools they sell.
Glenn Silva - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 78
总计 3,110
