跳转到主内容
HP Chromebook 11-v002dx Battery Replacement
你所需要的
  1. HP Chromebook 11-v002dx Battery Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Chromebook 11-v002dx Battery Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Working with your device plugged in may result in electric shock. Be sure to power off your device and unplug it from any power source before proceeding with step one.
    • Place your laptop bottom up on your work space.
    • Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
  2. HP Chromebook 11-v002dx Battery Replacement: 步骤 2 中的图像 1,3 HP Chromebook 11-v002dx Battery Replacement: 步骤 2 中的图像 2,3 HP Chromebook 11-v002dx Battery Replacement: 步骤 2 中的图像 3,3
    • Using a sharp tool, remove the six adhesives from the bottom of your laptop to expose the screwheads underneath. Two of the pads are small and four are larger.
  3. HP Chromebook 11-v002dx Battery Replacement: 步骤 3 中的图像 1,2 HP Chromebook 11-v002dx Battery Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to loosen the keyboard face from the device.
    • Start prying at one end of the laptop and slowly work your way around so as not to break the keyboard.
  4. HP Chromebook 11-v002dx Battery Replacement: 步骤 4 中的图像 1,2 HP Chromebook 11-v002dx Battery Replacement: 步骤 4 中的图像 2,2
    • Lift the keyboard so that the inner workings of the laptop are exposed.
    • Gently pull each of the two ribbons connecting the keyboard to the device so that neither ribbon is still connected to the device, only to the keyboard.
  5. HP Chromebook 11-v002dx Battery Replacement, Battery: 步骤 5 中的图像 1,2 HP Chromebook 11-v002dx Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Flip up the black tab on the far right of the wire ribbon.
    • Gently pull the wire out of the black holder on its right, then out of the left side as well.
  6. HP Chromebook 11-v002dx Battery Replacement: 步骤 6 中的图像 1,3 HP Chromebook 11-v002dx Battery Replacement: 步骤 6 中的图像 2,3 HP Chromebook 11-v002dx Battery Replacement: 步骤 6 中的图像 3,3
    • Using your Phillips #0 screwdriver, remove the five 0.2 mm screws from the battery.
  7. HP Chromebook 11-v002dx Battery Replacement: 步骤 7 中的图像 1,3 HP Chromebook 11-v002dx Battery Replacement: 步骤 7 中的图像 2,3 HP Chromebook 11-v002dx Battery Replacement: 步骤 7 中的图像 3,3
    • Pinch the edges of the white tab with the wires coming out of the end.
    • Gently remove the white tab with the wires from its holder on the motherboard.
  8. HP Chromebook 11-v002dx Battery Replacement: 步骤 8 中的图像 1,2 HP Chromebook 11-v002dx Battery Replacement: 步骤 8 中的图像 2,2
    • Gently remove the battery from the laptop completely.
    • You can either clean your battery and connection ports or completely replace it.
结论
2等其他人完成本指南。
Abby Zilvitis
于04/17/17注册
448 声望
创作了4篇指南
团队
Cal Poly, Team S14-G1, Banghart Spring 2017 Cal Poly, Team S14-G1, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G1
4 名成员
创作了5篇指南
一条评论
Insructions exerlent . What price battary
Yorky Jaggs - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 1,394
