跳转到主内容
HP Chromebook 11-2210nr SD Card Reader Replacement
你所需要的
  1. HP Chromebook 11-2210nr SD Card Reader Replacement, SD Card Reader: 步骤 1 中的图像 1,2 HP Chromebook 11-2210nr SD Card Reader Replacement, SD Card Reader: 步骤 1 中的图像 2,2
    • Turn over your laptop and remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 2 中的图像 1,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 2 中的图像 2,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 2 中的图像 3,3
    • Using the metal spudger, remove the two rubber pads that are closer to the hinge of the laptop.
    • Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The two bottom rubber pads do not contain screws, but you may check if you wish to be sure.
  3. HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 3 中的图像 1,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 3 中的图像 2,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 3 中的图像 3,3
    • Turn the Laptop over and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
  4. HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 4 中的图像 1,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 4 中的图像 2,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 4 中的图像 3,3
    • Carefully lift off the keyboard and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
    • Locate where the two ribbon wires are being held in place by two chips.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 5 中的图像 1,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 5 中的图像 2,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 5 中的图像 3,3
    • Using the nylon spudger, push the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • You must use the nylon spudger for this step. Any metal can damage your motherboard.
    • This step completely disconnects the keyboard to allow safe removal and replacement.
  6. HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 6 中的图像 1,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 6 中的图像 2,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 6 中的图像 3,3
    • Locate the SD card reader at the top left corner above the battery.
    • Flip up the plastic clasps holding the ZIF connectors into place by using the nylon spudger or your finger.
    • Gently slide out the ribbon cable, removing it from the SD Card Reader.
  7. HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 7 中的图像 1,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 7 中的图像 2,3 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 7 中的图像 3,3
    • Remove the two 4mm screws using a Phillips #1 screwdriver.
    • This successfully disconnects the SD port from the laptop.
  8. HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 8 中的图像 1,2 HP Chromebook 11-2210nr SD Card Reader Replacement: 步骤 8 中的图像 2,2
    • Gently lift and remove SD Card Reader component from laptop.
结论
Gerardo Cardona
于10/02/18注册
364 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 168
