跳转到主内容
HP Chromebook 11-2210nr LCD Screen Replacement
你所需要的
  1. HP Chromebook 11-2210nr LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove adhesive tabs using fine point tweezers or a metal spudger.
    • These adhesives are typically located at the bottom left and right corners of the screen.
  2. HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the one 3 mm screw located underneath both adhesive layers using a Phillips #0 screwdriver.
  3. HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 3 中的图像 1,2 HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Using a metal spudger, gently pry the front plastic frame (or bezel) off of the device by inserting the tool along the inside edge of the bezel.
    • Completely open the screen as far as possible to remove the bottom edge of the bezel from the laptop.
    • Be sure to disconnect the bezel from all the way around the screen before completely removing.
  4. HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 4 中的图像 1,2 HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the four black 3 mm screws along the left and right sides of the LCD screen using a Phillips #0 screwdriver.
  5. HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 5 中的图像 1,1
    • After removing all screws, gently lower the LCD screen onto the keyboard.
    • The LCD screen will not be completely disconnected from the laptop just yet.
  6. HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 6 中的图像 1,2 HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Gently use the spudger to pry off the tape on top of the gold chip. You may also use your hands to gently remove the tape.
  7. HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 7 中的图像 1,2 HP Chromebook 11-2210nr LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the display cable by gently sliding out the cable away from the LCD screen.
    • This action disconnects the LCD screen from the rest of the device, allowing it to be completely removed.
结论
另外一个人完成了本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 438
