跳转到主内容
HP Chromebook 11-2210nr Battery Replacement
你所需要的
  1. HP Chromebook 11-2210nr Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Chromebook 11-2210nr Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Position your closed laptop face down to remove the 9 visible 6 mm screws using a Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr Battery Replacement: 步骤 2 中的图像 1,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 2 中的图像 2,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 2 中的图像 3,3
    • Use a metal spudger to remove the two bottom rubber pads located closer to the hinge of the laptop.
    • Remove the two additional 6 mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The other two bottom rubber pads do not have screws beneath them.
  3. HP Chromebook 11-2210nr Battery Replacement: 步骤 3 中的图像 1,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 3 中的图像 2,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 3 中的图像 3,3
    • Turn the Laptop over, and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
    • Be careful when using the metal spudger as it could cause damage to the internals of the device. Don't push the spudger too deeply into the seam.
  4. HP Chromebook 11-2210nr Battery Replacement: 步骤 4 中的图像 1,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 4 中的图像 2,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 4 中的图像 3,3
    • Carefully lift the keyboard up and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
    • Locate where the two ribbon wires are being held in place by two locks.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr Battery Replacement: 步骤 5 中的图像 1,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 5 中的图像 2,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 5 中的图像 3,3
    • Using the nylon spudger, push the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is important to use the nylon spudger for this step to avoid any metal on metal circuit damage.
    • This step completely disconnects the keyboard to allow safe removal.
  6. HP Chromebook 11-2210nr Battery Replacement: 步骤 6 中的图像 1,2 HP Chromebook 11-2210nr Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the six 4 mm screws holding the battery in place with a Phillips #1 screwdriver.
  7. HP Chromebook 11-2210nr Battery Replacement: 步骤 7 中的图像 1,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 7 中的图像 2,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 7 中的图像 3,3
    • Carefully unplug the bundle power cable by pulling both edges towards you.
    • This successfully disconnects the battery from the laptop.
  8. HP Chromebook 11-2210nr Battery Replacement: 步骤 8 中的图像 1,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 8 中的图像 2,3 HP Chromebook 11-2210nr Battery Replacement: 步骤 8 中的图像 3,3
    • Carefully lift the battery and remove it from the laptop.
    • The battery may have an adhesive sticker attached to the bottom, if so apply more force when lifting up.
结论
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 342
