跳转到主内容
HP Chromebook 11 G8 EE Battery Replacement
你所需要的
  1. HP Chromebook 11 G8 EE Battery Replacement, Keyboard & Touchpad Assembly: 步骤 1 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Battery Replacement: 步骤 2 中的图像 1,2 HP Chromebook 11 G8 EE Battery Replacement: 步骤 2 中的图像 2,2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Battery Replacement: 步骤 3 中的图像 1,3 HP Chromebook 11 G8 EE Battery Replacement: 步骤 3 中的图像 2,3 HP Chromebook 11 G8 EE Battery Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Do not puncture or damage any parts of the battery.
    • Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
    • The speakers are removed in these images, but they don't need to be to replace the battery.
  5. HP Chromebook 11 G8 EE Battery Replacement: 步骤 5 中的图像 1,3 HP Chromebook 11 G8 EE Battery Replacement: 步骤 5 中的图像 2,3 HP Chromebook 11 G8 EE Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the four 3.5 mm Phillips #1 screws securing the battery.
    • If you've already removed the speakers, you'll only need to remove the two screws on the top of the battery, near the motherboard.
  6. HP Chromebook 11 G8 EE Battery Replacement: 步骤 6 中的图像 1,2 HP Chromebook 11 G8 EE Battery Replacement: 步骤 6 中的图像 2,2
    • Carefully lift the battery up and out.
结论
Julia Latura
于10/25/22注册
328 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S4G2
5 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 75
总计 692
