跳转到主内容
HP Chromebook 11 G6 EE Battery Replacement
你所需要的
  1. HP Chromebook 11 G6 EE Battery Replacement, Remove keyboard screws: 步骤 1 中的图像 1,1
    • Remove the screws from the bottom case.
    • Two M2.5x8 PH1 screws.
    • Six M2.5x6 PH1 screws.
  2. HP Chromebook 11 G6 EE Battery Replacement, Remove keyboard: 步骤 2 中的图像 1,2 HP Chromebook 11 G6 EE Battery Replacement, Remove keyboard: 步骤 2 中的图像 2,2
    • Use a plastic opening pick to release the clips that secure the keyboard.
    • Avoid too much prying force. If you pry too hard, you'll break your pick. The trick is to get the pick in just a little bit, and then run it along the edge of the device.
    • DO NOT use metal tools for this step.
  3. HP Chromebook 11 G6 EE Battery Replacement, Disconnect keyboard: 步骤 3 中的图像 1,1
    • Lift up the keyboard part way, being careful to not put stress on the keyboard and touchpad ribbon cables.
  4. HP Chromebook 11 G6 EE Battery Replacement, Disconnect keyboard: 步骤 4 中的图像 1,3 HP Chromebook 11 G6 EE Battery Replacement, Disconnect keyboard: 步骤 4 中的图像 2,3 HP Chromebook 11 G6 EE Battery Replacement, Disconnect keyboard: 步骤 4 中的图像 3,3
    • Disconnect the keyboard ZIF connector
  5. HP Chromebook 11 G6 EE Battery Replacement, Disconnect touchpad: 步骤 5 中的图像 1,2 HP Chromebook 11 G6 EE Battery Replacement, Disconnect touchpad: 步骤 5 中的图像 2,2
    • Disconnect touchpad ZIF connector.
    • Now you can remove the keyboard assembly completely.
    • If your replacement keyboard came with touchpad and cable, you can start reassembling the computer now. If you need to retrieve the touchpad from the old keyboard, keep reading.
  6. HP Chromebook 11 G6 EE Battery Replacement, Remove touchpad: 步骤 7 中的图像 1,1
    • Lift up the plastic guard covering the three PH0 M2x2 screws and remove them.
    • Lift the touchpad out and place into new keyboard.
    • Be sure to evenly tighten the touchpad screws during reinstallation. Even a small variance can lead to a touchpad that feels "off".
  7. HP Chromebook 11 G6 EE Battery Replacement, Battery: 步骤 8 中的图像 1,3 HP Chromebook 11 G6 EE Battery Replacement, Battery: 步骤 8 中的图像 2,3 HP Chromebook 11 G6 EE Battery Replacement, Battery: 步骤 8 中的图像 3,3
    • Detach the battery from the motherboard.
  8. HP Chromebook 11 G6 EE Battery Replacement: 步骤 9 中的图像 1,2 HP Chromebook 11 G6 EE Battery Replacement: 步骤 9 中的图像 2,2
    • Unscrew the battery from the shell of the laptop.
  9. HP Chromebook 11 G6 EE Battery Replacement: 步骤 10 中的图像 1,1
    • Gently lift the battery from the laptop frame.
结论
另外一个人完成了本指南。
一条评论
missing instructions. To remove the battery you need to remove the speakers and unscrew 2# m2 ph 2.2mm screws. Also unlisted screw sizes and amounts on number 9
Joshua Taylor - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 42
总计 873
