跳转到主内容
HP Chromebook 11 G4 Keyboard Replacement
你所需要的
  1. HP Chromebook 11 G4 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Keyboard Replacement: 步骤 2 中的图像 1,2 HP Chromebook 11 G4 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Keyboard Replacement: 步骤 3 中的图像 1,2 HP Chromebook 11 G4 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Keyboard Replacement: 步骤 5 中的图像 1,2 HP Chromebook 11 G4 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 Keyboard Replacement: 步骤 7 中的图像 1,3 HP Chromebook 11 G4 Keyboard Replacement: 步骤 7 中的图像 2,3 HP Chromebook 11 G4 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Remove the keyboard assembly by lifting it off the laptop base.
结论
3等其他人完成本指南。
Jair Herrera
于04/26/17注册
694 声望
创作了4篇指南
团队
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G5
5 名成员
创作了15篇指南
3条评论
How do you remove the keyboard from the assembly though? And I wish there was a mention of the fact that the heat sink is attached to the keyboard assembly.
Kyle B - 回复
Same question as the person above. I need to remove the keyboard from the assembly.
Stephen Mason - 回复
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
Nacho Biniz - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 22
总计 9,217
