跳转到主内容
HP Chromebook 11 G4 Battery Replacement
你所需要的
  1. HP Chromebook 11 G4 Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Battery Replacement: 步骤 2 中的图像 1,2 HP Chromebook 11 G4 Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Battery Replacement: 步骤 3 中的图像 1,2 HP Chromebook 11 G4 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 Battery Replacement: 步骤 4 中的图像 1,1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Battery Replacement: 步骤 5 中的图像 1,2 HP Chromebook 11 G4 Battery Replacement: 步骤 5 中的图像 2,2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 Battery Replacement: 步骤 7 中的图像 1,3 HP Chromebook 11 G4 Battery Replacement: 步骤 7 中的图像 2,3 HP Chromebook 11 G4 Battery Replacement: 步骤 7 中的图像 3,3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 Battery Replacement, Battery: 步骤 9 中的图像 1,2 HP Chromebook 11 G4 Battery Replacement, Battery: 步骤 9 中的图像 2,2
    • Remove the six 4mm Phillips #1 screws.
  10. HP Chromebook 11 G4 Battery Replacement: 步骤 10 中的图像 1,2 HP Chromebook 11 G4 Battery Replacement: 步骤 10 中的图像 2,2
    • Disconnect the bundled power cable by grasping both edges with your fingers and pulling.
  11. HP Chromebook 11 G4 Battery Replacement: 步骤 11 中的图像 1,1
    • Lift the battery out of the laptop.
结论
27等其他人完成本指南。
团队
Cal Poly, Team S23-G5, Livingston Spring 2017 Cal Poly, Team S23-G5, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G5
3 名成员
创作了6篇指南
7条评论
wow so this is what computer technicians do.
88 88 - 回复
Christopher, your step by step is superb! I am one grateful chicky. Thanks to your guide, I didn't have to replace my laptop! It worked like a charm, despite not owning a spudger. I had to improvise and used a butter knife for tha unclipping of keyboard and my fingernails to unclip tha component clips and didn't even damage my rubber pads! Thank you so very much!!!
Jammie Brasher - 回复
Video was great. Disassembly and assembly took about 1 hour
Jorge De Joya - 回复
Measured power supply voltage as 6V. Not sure if this is enough to bring down the computer. Spec says is should be 7.7Vdc.
Jorge De Joya - 回复
Excellent! So easy to follow! Thank you for the well written guide and tips.
Martha Webb - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 31
过去 30 天: 109
总计 62,122
