跳转到主内容
HP Chromebook 11 G3 SD Card Reader Module Replacement
你所需要的
  1. HP Chromebook 11 G3 SD Card Reader Module Replacement, Keyboard Mount: 步骤 1 中的图像 1,2 HP Chromebook 11 G3 SD Card Reader Module Replacement, Keyboard Mount: 步骤 1 中的图像 2,2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 SD Card Reader Module Replacement: 步骤 2 中的图像 1,2 HP Chromebook 11 G3 SD Card Reader Module Replacement: 步骤 2 中的图像 2,2
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 SD Card Reader Module Replacement: 步骤 3 中的图像 1,1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 SD Card Reader Module Replacement: 步骤 4 中的图像 1,3 HP Chromebook 11 G3 SD Card Reader Module Replacement: 步骤 4 中的图像 2,3 HP Chromebook 11 G3 SD Card Reader Module Replacement: 步骤 4 中的图像 3,3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 SD Card Reader Module Replacement: 步骤 5 中的图像 1,1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 SD Card Reader Module Replacement, SD Card Reader Module: 步骤 6 中的图像 1,2 HP Chromebook 11 G3 SD Card Reader Module Replacement, SD Card Reader Module: 步骤 6 中的图像 2,2
    • On the module, use a spudger to lift the small ZIF retaining flap for the ribbon cable connecting the SD card reader to the motherboard.
    • Gently pull the ribbon cable out of its socket.
  7. HP Chromebook 11 G3 SD Card Reader Module Replacement: 步骤 7 中的图像 1,1
    • Remove the two Phillips #00 6mm screws that attach the module to the laptop.
  8. HP Chromebook 11 G3 SD Card Reader Module Replacement: 步骤 8 中的图像 1,1
    • Lift the module up and out of the laptop.
结论
另外一个人完成了本指南。
Rahul Goyal
于04/26/17注册
1,369 声望
创作了10篇指南
团队
Cal Poly, Team S23-G3, Livingston Spring 2017 Cal Poly, Team S23-G3, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 403
