跳转到主内容
HP Chromebook 11 G3 Keyboard Mount Replacement
你所需要的
  1. HP Chromebook 11 G3 Keyboard Mount Replacement, Keyboard Mount: 步骤 1 中的图像 1,2 HP Chromebook 11 G3 Keyboard Mount Replacement, Keyboard Mount: 步骤 1 中的图像 2,2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Keyboard Mount Replacement: 步骤 2 中的图像 1,2 HP Chromebook 11 G3 Keyboard Mount Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Keyboard Mount Replacement: 步骤 3 中的图像 1,1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Keyboard Mount Replacement: 步骤 4 中的图像 1,3 HP Chromebook 11 G3 Keyboard Mount Replacement: 步骤 4 中的图像 2,3 HP Chromebook 11 G3 Keyboard Mount Replacement: 步骤 4 中的图像 3,3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Keyboard Mount Replacement: 步骤 5 中的图像 1,1
    • Lift the keyboard mount out of the laptop.
结论
2等其他人完成本指南。
Rahul Goyal
于04/26/17注册
1,369 声望
创作了10篇指南
团队
Cal Poly, Team S23-G3, Livingston Spring 2017 Cal Poly, Team S23-G3, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 365
