跳转到主内容
HP Chromebook 14-x013dx Motherboard Replacement
你所需要的
  1. HP Chromebook  14-x013dx Motherboard Replacement, Keyboard, Touchpad: 步骤 1 中的图像 1,2 HP Chromebook  14-x013dx Motherboard Replacement, Keyboard, Touchpad: 步骤 1 中的图像 2,2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook  14-x013dx Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook  14-x013dx Motherboard Replacement: 步骤 3 中的图像 1,2 HP Chromebook  14-x013dx Motherboard Replacement: 步骤 3 中的图像 2,2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook  14-x013dx Motherboard Replacement: 步骤 4 中的图像 1,2 HP Chromebook  14-x013dx Motherboard Replacement: 步骤 4 中的图像 2,2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook  14-x013dx Motherboard Replacement: 步骤 5 中的图像 1,3 HP Chromebook  14-x013dx Motherboard Replacement: 步骤 5 中的图像 2,3 HP Chromebook  14-x013dx Motherboard Replacement: 步骤 5 中的图像 3,3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook  14-x013dx Motherboard Replacement, Battery: 步骤 6 中的图像 1,2 HP Chromebook  14-x013dx Motherboard Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook  14-x013dx Motherboard Replacement: 步骤 7 中的图像 1,2 HP Chromebook  14-x013dx Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook  14-x013dx Motherboard Replacement: 步骤 8 中的图像 1,2 HP Chromebook  14-x013dx Motherboard Replacement: 步骤 8 中的图像 2,2
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook  14-x013dx Motherboard Replacement: 步骤 9 中的图像 1,1
    • Lift the battery out of the laptop case.
  10. HP Chromebook  14-x013dx Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,3 HP Chromebook  14-x013dx Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,3 HP Chromebook  14-x013dx Motherboard Replacement, Motherboard: 步骤 10 中的图像 3,3
    • Carefully remove the 4 connections.
  11. HP Chromebook  14-x013dx Motherboard Replacement: 步骤 11 中的图像 1,3 HP Chromebook  14-x013dx Motherboard Replacement: 步骤 11 中的图像 2,3 HP Chromebook  14-x013dx Motherboard Replacement: 步骤 11 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the seven 2mm screws holding the motherboard in place.
    • Gently lift the motherboard out of the laptop case.
结论
另外一个人完成了本指南。
Eile Woeltje
于11/06/19注册
304 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Stella Fall 2019 IUPUI, Team S1-G3, Stella Fall 2019 的会员
IUPUI-STELLA-F19S1G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 537
