跳转到主内容
简介
Use this guide to help disassemble the keyboard panel for any parts needing to be replaced located under the keyboard panel.
  1. HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 2 中的图像 1,2 HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 2 中的图像 2,2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 3 中的图像 1,2 HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 3 中的图像 2,2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 4 中的图像 1,2 HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 4 中的图像 2,2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 5 中的图像 1,2 HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 5 中的图像 2,2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 6 中的图像 1,2 HP Beats Special Edition 15-p390nr Keyboard Replacement: 步骤 6 中的图像 2,2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 35
总计 2,119
