简介
This guide will help you if your rear-facing camera is cracked or damaged. You may need to pull a little bit to remove the camera, it is well secured in the tablet.
你所需要的
Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
Lift the rear-facing camera out of its compartment using the tweezers.
即将完成!
结论
