跳转到主内容
HP 8 1401 Back Panel Replacement
你所需要的
  1. HP 8 1401 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Back Panel Replacement: 步骤 2 中的图像 1,1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Back Panel Replacement: 步骤 3 中的图像 1,2 HP 8 1401 Back Panel Replacement: 步骤 3 中的图像 2,2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
结论
To reassemble your device, follow these instructions in reverse order. Align the front and back panels and press them together, then screw in the four screws.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 9
过去 30 天: 11
总计 227
