跳转到主内容
HP 7 Plus 1302 Power and Volume Button Replacement
你所需要的
  1. HP 7 Plus 1302 Power and Volume Button Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Power and Volume Button Replacement: 步骤 2 中的图像 1,2 HP 7 Plus 1302 Power and Volume Button Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Power and Volume Button Replacement: 步骤 3 中的图像 1,2 HP 7 Plus 1302 Power and Volume Button Replacement: 步骤 3 中的图像 2,2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Power and Volume Button Replacement, Power and Volume Button: 步骤 4 中的图像 1,1
    • Locate the power and volume buttons on the right side
  5. HP 7 Plus 1302 Power and Volume Button Replacement: 步骤 5 中的图像 1,2 HP 7 Plus 1302 Power and Volume Button Replacement: 步骤 5 中的图像 2,2
    • Pop out the power and volume buttons with your hands
结论
Shannon Suttles
于01/29/17注册
225 声望
创作了2篇指南
团队
IUPUI, Team 1-4, Baechle Spring 2017 IUPUI, Team 1-4, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S1G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 263
