简介
If the device volume and/ or power buttons are unresponsive then it may be necessary to replace them. The most challenging step to fix both buttons is removing the back cover. The tools listed (or similar) are necessary for both buttons to function properly.
你所需要的
Use the T5 Torx screwdriver and remove the T5x3mm screws on all four corners of the device.
即将完成!
结论
另外一个人完成了本指南。
