跳转到主内容
HP 7 PLUS 1301 Speaker Replacement
你所需要的
  1. HP 7 PLUS 1301 Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 HP 7 PLUS 1301 Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Make sure the device is off and not plugged in before starting.
    • Use the Torx T5 screwdriver and remove the 3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Speaker Replacement: 步骤 2 中的图像 1,2 HP 7 PLUS 1301 Speaker Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Speaker Replacement: 步骤 3 中的图像 1,2 HP 7 PLUS 1301 Speaker Replacement: 步骤 3 中的图像 2,2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Speaker Replacement: 步骤 4 中的图像 1,2 HP 7 PLUS 1301 Speaker Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, carefully remove the speaker connector from the socket.
  5. HP 7 PLUS 1301 Speaker Replacement: 步骤 5 中的图像 1,3 HP 7 PLUS 1301 Speaker Replacement: 步骤 5 中的图像 2,3 HP 7 PLUS 1301 Speaker Replacement: 步骤 5 中的图像 3,3
    • Insert a spudger in the bottom right of the speaker. It makes the speaker easier to come off.
    • Carefully remove the speaker with your hand.
    • Some force needs to be applied here due to the adhesive on the other side of the speaker.
结论
另外一个人完成了本指南。
Shao-Hung Hsiao
于02/05/19注册
201 声望
撰写一个指南
团队
UC Davis, Team S20-G6, Lore Winter 2019 UC Davis, Team S20-G6, Lore Winter 2019 的会员
UCD-LORE-W19S20G6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 117
