跳转到主内容
HP 7 PLUS 1301 Battery Replacement
你所需要的
  1. HP 7 PLUS 1301 Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP 7 PLUS 1301 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the device is off and not plugged in before starting.
    • Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
  2. HP 7 PLUS 1301 Battery Replacement: 步骤 2 中的图像 1,2 HP 7 PLUS 1301 Battery Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Battery Replacement: 步骤 3 中的图像 1,2 HP 7 PLUS 1301 Battery Replacement: 步骤 3 中的图像 2,2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Battery Replacement: 步骤 4 中的图像 1,2 HP 7 PLUS 1301 Battery Replacement: 步骤 4 中的图像 2,2
    • Push out the connector to disconnect the battery.
    • Move the battery connector clear of the connector socket.
  5. HP 7 PLUS 1301 Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the battery by sliding a plastic spudger under the battery. Use an adhesive remover if available under the battery to make it easier for the battery to come off.
结论
另外一个人完成了本指南。
Adanna Ilori
于02/05/19注册
301 声望
创作了2篇指南
团队
UC Davis, Team S20-G6, Lore Winter 2019 UC Davis, Team S20-G6, Lore Winter 2019 的会员
UCD-LORE-W19S20G6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 740
