跳转到主内容
HP 7 1800 Speaker Replacement
你所需要的
  1. HP 7 1800 Speaker Replacement, Remove the back panel: 步骤 1 中的图像 1,2 HP 7 1800 Speaker Replacement, Remove the back panel: 步骤 1 中的图像 2,2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Speaker Replacement, Remove the battery: 步骤 2 中的图像 1,3 HP 7 1800 Speaker Replacement, Remove the battery: 步骤 2 中的图像 2,3 HP 7 1800 Speaker Replacement, Remove the battery: 步骤 2 中的图像 3,3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Speaker Replacement, Desolder the speaker wires: 步骤 3 中的图像 1,1
    • Desolder the two leads of the speaker wire that are connected to the motherboard.
  4. HP 7 1800 Speaker Replacement, Remove the speaker: 步骤 4 中的图像 1,1
    • Using tweezers, gently pull the speaker off of the metal plate.
    • The speaker is held onto the metal plate with light adhesive. It will require a little force to peel off.
结论
TMD
于01/21/15注册
765 声望
创作了5篇指南
团队
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 的会员
USFT-BROWN-W15S4G1
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 208
