跳转到主内容
HP 7 1800 Motherboard Replacement
你所需要的
  1. HP 7 1800 Motherboard Replacement, Remove the back panel: 步骤 1 中的图像 1,2 HP 7 1800 Motherboard Replacement, Remove the back panel: 步骤 1 中的图像 2,2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Motherboard Replacement, Remove the battery: 步骤 2 中的图像 1,3 HP 7 1800 Motherboard Replacement, Remove the battery: 步骤 2 中的图像 2,3 HP 7 1800 Motherboard Replacement, Remove the battery: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: 步骤 3 中的图像 1,2 HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: 步骤 4 中的图像 1,2 HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: 步骤 4 中的图像 2,2
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Motherboard Replacement, Unscrew the 7 silver screws from the logic board: 步骤 5 中的图像 1,1
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Motherboard Replacement, Unplug the front facing camera from the logic board: 步骤 6 中的图像 1,1
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Motherboard Replacement, Remove the logic board: 步骤 7 中的图像 1,1
    • Carefully lift the motherboard directly up.
结论
TMD
于01/21/15注册
765 声望
创作了5篇指南
团队
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 的会员
USFT-BROWN-W15S4G1
4 名成员
创作了14篇指南
一条评论
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
jakehittinger - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 949
