跳转到主内容
HP 7 1800 Battery Replacement
你所需要的
  1. HP 7 1800 Battery Replacement, Remove the back panel: 步骤 1 中的图像 1,2 HP 7 1800 Battery Replacement, Remove the back panel: 步骤 1 中的图像 2,2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Battery Replacement, Remove the battery: 步骤 2 中的图像 1,3 HP 7 1800 Battery Replacement, Remove the battery: 步骤 2 中的图像 2,3 HP 7 1800 Battery Replacement, Remove the battery: 步骤 2 中的图像 3,3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
结论
另外一个人完成了本指南。
TMD
于01/21/15注册
765 声望
创作了5篇指南
团队
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 的会员
USFT-BROWN-W15S4G1
4 名成员
创作了14篇指南
2条评论
This is the OEM Replacement Battery, 740963-001, HP Spare: 739691-001, but you can find an OEM replacement the fits and works perfectly will be the Dell Venue 7 battery -17.29Wh 4550 mAh P708 DHM0J and half the price.
Santiago - 回复
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
Glenn Wemmer - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 3,335
