简介
This guide will help you replace the battery in your HP 7 1800 in a fast and safe manner. You will need a Spudger to open the case to get inside to the battery.
你所需要的
Carefully insert a Spudger into one of the corners of the tablet.
Slide the Spudger along the edge popping the tabs out along the way.
另外一个人完成了本指南。
2条评论
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
