跳转到主内容
HP 255 G8 Hard Drive Replacement
你所需要的
  1. HP 255 G8 Hard Drive Replacement, Hard drive: 步骤 1 中的图像 1,2 HP 255 G8 Hard Drive Replacement, Hard drive: 步骤 1 中的图像 2,2
    • Ensure that your laptop is powered off and it is disconnected from all peripherals and the charger.
    • Flip your laptop over so the bottom case is facing up.
    • Use a spudger to remove the two rubber strips covering the screws.
    • Keep the screw covers to replace them after you have finished the repair.
  2. HP 255 G8 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 10 screws securing the bottom case.
  3. HP 255 G8 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Slide the optical drive/disk drive out to remove it.
    • If you are struggling to remove the optical drive, hold the laptop down with your right hand and continue to pull with your left.
  4. HP 255 G8 Hard Drive Replacement: 步骤 4 中的图像 1,2 HP 255 G8 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Carefully lift the back panel off of the laptop.
    • Use a Phillips #00 screwdriver to remove four screws securing the hard drive.
  5. HP 255 G8 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Carefully lift and remove the hard drive bracket.
  6. HP 255 G8 Hard Drive Replacement: 步骤 6 中的图像 1,3 HP 255 G8 Hard Drive Replacement: 步骤 6 中的图像 2,3 HP 255 G8 Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Lift the hard drive and hold it at a 30-degree angle.
    • Detach the hard drive from the connector by sliding the hard drive to the left.
结论
另外一个人完成了本指南。
Columbus Souratha
于03/05/24注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 7-12, Grodsky Spring 2024 CSU Los Angeles, Team 7-12, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S7G12
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 18
总计 33
