跳转到主内容
HP 2000 - 2D22DX Wireless Card Replacement
你所需要的
  1. HP 2000 - 2D22DX Wireless Card Replacement, Battery: 步骤 1 中的图像 1,2 HP 2000 - 2D22DX Wireless Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX Wireless Card Replacement: 步骤 2 中的图像 1,2 HP 2000 - 2D22DX Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 1,2 HP 2000 - 2D22DX Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 2,2
    • Locate the RAM compartment cover below the battery compartment.
    • Locate the Phillips head screw securing RAM compartment to plastic chassis.
    • Loosen screw that is securing the RAM compartment with #00 Phillips head screwdriver.
    • Screw is permanently attached to the RAM compartment cover. Do not try to remove completely.
  4. HP 2000 - 2D22DX Wireless Card Replacement: 步骤 4 中的图像 1,2 HP 2000 - 2D22DX Wireless Card Replacement: 步骤 4 中的图像 2,2
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
  5. HP 2000 - 2D22DX Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Locate the wireless module next to the RAM slots.
  6. HP 2000 - 2D22DX Wireless Card Replacement: 步骤 6 中的图像 1,3 HP 2000 - 2D22DX Wireless Card Replacement: 步骤 6 中的图像 2,3 HP 2000 - 2D22DX Wireless Card Replacement: 步骤 6 中的图像 3,3
    • Locate the gold connecting wire attached to the wireless module. It is labeled with a small sticker that has a circled number one.
    • Using a plastic spudger, disconnect the gold-end of the connecting wire from the wireless module.
    • Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the gold wire and its respective port on the wireless module. Both are very fragile and can be easily ruined.
  7. HP 2000 - 2D22DX Wireless Card Replacement: 步骤 7 中的图像 1,3 HP 2000 - 2D22DX Wireless Card Replacement: 步骤 7 中的图像 2,3 HP 2000 - 2D22DX Wireless Card Replacement: 步骤 7 中的图像 3,3
    • Locate the small Phillips head screw in the top right corner of the wireless module.
    • Using a #00 Phillips head screwdriver, remove the screw and set aside.
    • The wireless module should now pop up from its slot at a 45 degree angle.
  8. HP 2000 - 2D22DX Wireless Card Replacement: 步骤 8 中的图像 1,1
    • Slowly slide the wireless module straight out from its slot in the logic board.
    • Maintain the 45 degree angle of the wireless module until all pins are disconnected. Failure to do so may result in breaking the wireless module connecting pins.
结论
5等其他人完成本指南。
Conor Most
于04/14/14注册
2,723 声望
创作了6篇指南
团队
Cal Poly, Team 3-40, Maness Spring 2014 Cal Poly, Team 3-40, Maness Spring 2014 的会员
CPSU-MANESS-S14S3G40
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 12
总计 2,281
