跳转到主内容
HP 2000 - 2D22DX RAM Replacement
你所需要的
  1. HP 2000 - 2D22DX RAM Replacement, Battery: 步骤 1 中的图像 1,2 HP 2000 - 2D22DX RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX RAM Replacement: 步骤 2 中的图像 1,2 HP 2000 - 2D22DX RAM Replacement: 步骤 2 中的图像 2,2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX RAM Replacement, RAM: 步骤 3 中的图像 1,2 HP 2000 - 2D22DX RAM Replacement, RAM: 步骤 3 中的图像 2,2
    • After battery removal, the RAM compartment cover is exposed.
    • Locate the Phillips head screw seen in the second picture. It secures the RAM compartment to the plastic chassis.
    • Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
  4. HP 2000 - 2D22DX RAM Replacement: 步骤 4 中的图像 1,2 HP 2000 - 2D22DX RAM Replacement: 步骤 4 中的图像 2,2
    • Once the screw is sufficiently loosened, gently unclip the RAM compartment cover from its slots in the plastic chassis.
    • Pull the compartment door out and away from the chassis, exposing the black film covering the RAM module.
  5. HP 2000 - 2D22DX RAM Replacement: 步骤 5 中的图像 1,3 HP 2000 - 2D22DX RAM Replacement: 步骤 5 中的图像 2,3 HP 2000 - 2D22DX RAM Replacement: 步骤 5 中的图像 3,3
    • Move the black plastic film to the side to locate the RAM slots.
    • Locate the metal clips holding the RAM card in place.
    • Using your fingers, push the metal clips out and away from the RAM module until the RAM module pops up at a 45 degree angle.
  6. HP 2000 - 2D22DX RAM Replacement: 步骤 6 中的图像 1,1
    • Hold the black plastic film away from the RAM slots. Grasp the edge of the RAM card and slide it out at a 45 degree angle.
    • Maintain the 45 degree angle of the RAM card until all pins are disengaged. Failure to do so may result in pin breakage.
结论
6等其他人完成本指南。
Conor Most
于04/14/14注册
2,723 声望
创作了6篇指南
团队
Cal Poly, Team 3-40, Maness Spring 2014 Cal Poly, Team 3-40, Maness Spring 2014 的会员
CPSU-MANESS-S14S3G40
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 3,958
