跳转到主内容
HP 17-x173dx CPU Cooling Fan Replacement
你所需要的
  1. HP 17-x173dx CPU Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,2 HP 17-x173dx CPU Cooling Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin by sliding the left tab to the unlock position
  2. HP 17-x173dx CPU Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Push each of the two tabs in the direction specified by the picture.
  3. HP 17-x173dx CPU Cooling Fan Replacement: 步骤 3 中的图像 1,3 HP 17-x173dx CPU Cooling Fan Replacement: 步骤 3 中的图像 2,3 HP 17-x173dx CPU Cooling Fan Replacement: 步骤 3 中的图像 3,3
    • Slide and hold the right tab to the left, while gently pushing out the battery with your thumbs
  4. HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: 步骤 4 中的图像 1,2 HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: 步骤 4 中的图像 2,2
    • Use a spudger or Jimmy to lift the plastic back cover starting from the back right side near the vents.
    • Remove the back cover of the device by continuing to lift the plastic around the entire perimeter of the device.
  5. HP 17-x173dx CPU Cooling Fan Replacement: 步骤 5 中的图像 1,3 HP 17-x173dx CPU Cooling Fan Replacement: 步骤 5 中的图像 2,3 HP 17-x173dx CPU Cooling Fan Replacement: 步骤 5 中的图像 3,3
    • Using the Phillips #0 screwdriver, unscrew four heat-sink screws (These will unscrew, but will stay attached to the heat-sink), and one screw towards the top.
    • Disconnect the power cable.
  6. HP 17-x173dx CPU Cooling Fan Replacement: 步骤 6 中的图像 1,2 HP 17-x173dx CPU Cooling Fan Replacement: 步骤 6 中的图像 2,2
    • Remove the CPU cooling fan.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 375
