跳转到主内容
HP 17-x027ds Wifi Card Replacement
你所需要的
  1. HP 17-x027ds Wifi Card Replacement, WiFi Card: 步骤 1 中的图像 1,3 HP 17-x027ds Wifi Card Replacement, WiFi Card: 步骤 1 中的图像 2,3 HP 17-x027ds Wifi Card Replacement, WiFi Card: 步骤 1 中的图像 3,3
    • Flip the laptop so you can see the serial number and the four 7mm screws in all the corners.
    • Click the hinges by pushing them inward, which are located at the top.
    • Remove the battery by pulling it out.
  2. HP 17-x027ds Wifi Card Replacement: 步骤 2 中的图像 1,3 HP 17-x027ds Wifi Card Replacement: 步骤 2 中的图像 2,3 HP 17-x027ds Wifi Card Replacement: 步骤 2 中的图像 3,3
    • Remove the 2 pieces of black tape that are each covering a 7mm screw at the top corners of the laptop.
    • When removing the 2 black pieces of tape, keep the tape so you can place it back on the laptop again when reassembling.
    • Remove the fourteen 7mm screws with a JIS #00 screwdriver.
  3. HP 17-x027ds Wifi Card Replacement: 步骤 3 中的图像 1,2 HP 17-x027ds Wifi Card Replacement: 步骤 3 中的图像 2,2
    • Lift the bottom cover of the laptop with a metal spudger by wedging the sides first and going all around.
    • The cover is difficult to lift, so use extreme force.
  4. HP 17-x027ds Wifi Card Replacement: 步骤 4 中的图像 1,3 HP 17-x027ds Wifi Card Replacement: 步骤 4 中的图像 2,3 HP 17-x027ds Wifi Card Replacement: 步骤 4 中的图像 3,3
    • Carefully pull the two cables attached to the CPU.
    • They are labeled 1 and 2. When putting the cables back, make sure to put them in the correct section.
    • Remove the screw holding down the CPU with the same screwdriver tip as before.
    • Gently pull on the CPU to remove it.
结论
Tyrin
于09/20/18注册
188 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 409
