跳转到主内容
HP 17-x027ds LCD Screen Replacement
你所需要的
  1. HP 17-x027ds LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 HP 17-x027ds LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 HP 17-x027ds LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Open the laptop so you can see the screen.
    • Remove the bezel with firm, constant pressure to create a slight gap between the bezel and screen (plastic outlining of screen) with a plastic opening tool.
    • Remove the bezel by starting on the sides of the screen and lastly removing the top outlining.
    • When removing the bezel, be cautious not to use too much force or else you will damage the screen. Apply just enough pressure to create a gap between the bezel and screen.
  2. HP 17-x027ds LCD Screen Replacement: 步骤 2 中的图像 1,3 HP 17-x027ds LCD Screen Replacement: 步骤 2 中的图像 2,3 HP 17-x027ds LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Lift the bezel off the screen to see the outlines of the LCD screen.
    • Remove the four black 3mm screws in each corner of the screen with a JIS #1 screwdriver.
    • Remove the two silver 4mm screws located at the top of the screen with a JIS #1 screwdriver.
  3. HP 17-x027ds LCD Screen Replacement: 步骤 3 中的图像 1,2 HP 17-x027ds LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the LCD screen and place it on the keyboard.
    • Disconnect the video cable to completely detach the LCD screen.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 787
