简介
This guide will assist you in replacing the hard drive. You will need to replace the hard drive if the laptop has bootup failures, frequent shutdowns, and if you hear clicking or grinding noises from the hard drive.
你所需要的
Flip the laptop so you can see the serial number and the four 7mm screws in all the corners.
Click the hinges by pushing them inward, which are located at the top of the laptop.
Remove the battery by pulling it out.
Remove the two pieces of black tape that are each covering a 7mm screw at the top corners of the laptop.
Remove the fourteen 7mm JIS #1 screws.
另外一个人完成了本指南。
