跳转到主内容
HP 17-bs049dx Motherboard Replacement
你所需要的
  1. HP 17-bs049dx Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  2. HP 17-bs049dx Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  3. HP 17-bs049dx Motherboard Replacement: 步骤 3 中的图像 1,2 HP 17-bs049dx Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  4. HP 17-bs049dx Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  5. HP 17-bs049dx Motherboard Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Lift the USB port over and away from hard drive.
  6. HP 17-bs049dx Motherboard Replacement: 步骤 6 中的图像 1,2 HP 17-bs049dx Motherboard Replacement: 步骤 6 中的图像 2,2
    • Lift rubber black tabs located on the hard drive upwards.
    • Disconnect hard drive from motherboard by pulling towards you.
  7. HP 17-bs049dx Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,3 HP 17-bs049dx Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,3 HP 17-bs049dx Motherboard Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Make sure to unplug everything connected to the motherboard.
    • Be gentle with this step.
  8. HP 17-bs049dx Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the screws (7.51mm) with a Phillips #0 screwdriver.
    • Once all of the screws are removed, remove the motherboard from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 801
