跳转到主内容
加入维修社区 - 创建账户
HP 17-bs049dx Fan Replacement
你所需要的
  1. HP 17-bs049dx Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx Fan Replacement, Back Panel: 步骤 2 中的图像 1,1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx Fan Replacement: 步骤 3 中的图像 1,1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx Fan Replacement: 步骤 4 中的图像 1,2 HP 17-bs049dx Fan Replacement: 步骤 4 中的图像 2,2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx Fan Replacement: 步骤 5 中的图像 1,1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. HP 17-bs049dx Fan Replacement, Fan: 步骤 6 中的图像 1,3 HP 17-bs049dx Fan Replacement, Fan: 步骤 6 中的图像 2,3 HP 17-bs049dx Fan Replacement, Fan: 步骤 6 中的图像 3,3
    • Unscrew all four screws connecting the heatsink to the motherboard.
    • The screws holding the heat sink will not detach from the heat sink.
    • All four screws must be loosened before removing the heat sink.
    • After loosening all screws remove the heat sink and store it in a safe place.
  7. HP 17-bs049dx Fan Replacement: 步骤 7 中的图像 1,1
    • After removing the heat sink, disconnect the cable connecting the fan to the motherboard.
  8. HP 17-bs049dx Fan Replacement: 步骤 8 中的图像 1,1
    • Remove the old fan from the device.
结论
Juan Seoane-Seri
于09/24/18注册
183 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 936
