跳转到主内容
HP 15-r137wm TouchSmart Keyboard Replacement
你所需要的
  1. HP 15-r137wm TouchSmart Keyboard Replacement, Front Panel Assembly: 步骤 1 中的图像 1,3 HP 15-r137wm TouchSmart Keyboard Replacement, Front Panel Assembly: 步骤 1 中的图像 2,3 HP 15-r137wm TouchSmart Keyboard Replacement, Front Panel Assembly: 步骤 1 中的图像 3,3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Keyboard Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Keyboard Replacement: 步骤 3 中的图像 1,1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Keyboard Replacement: 步骤 4 中的图像 1,2 HP 15-r137wm TouchSmart Keyboard Replacement: 步骤 4 中的图像 2,2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,2 HP 15-r137wm TouchSmart Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Keyboard Replacement: 步骤 6 中的图像 1,2 HP 15-r137wm TouchSmart Keyboard Replacement: 步骤 6 中的图像 2,2
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
结论
3等其他人完成本指南。
Ross B Jacques
于10/18/17注册
881 声望
创作了7篇指南
团队
UMass Dartmouth, Team S4-G4, Julie Fall 2017 UMass Dartmouth, Team S4-G4, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G4
3 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 586
