跳转到主内容
HP 15-g020dx Hard Drive Replacement
你所需要的
  1. HP 15-g020dx Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over so that the bottom is facing you.
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g020dx Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Place your finger on the left latch and slide it towards the center of the laptop to remove the battery.
  3. HP 15-g020dx Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the laptop.
  4. HP 15-g020dx Hard Drive Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to lift the panel with the keyboard.
  5. HP 15-g020dx Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Take the keyboard and the section of the panel surrounding the keyboard apart.
  6. HP 15-g020dx Hard Drive Replacement: 步骤 6 中的图像 1,2 HP 15-g020dx Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Lift the flip covering the connection port and remove the connecting strip to detach the keyboard from the motherboard.
  7. HP 15-g020dx Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,2 HP 15-g020dx Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Remove the two screws securing the hard drive to the device using the Phillips #0 screwdriver.
    • Warning: the hard drive and two screws are missing in the picture. The positions of screws are marked out.
  8. HP 15-g020dx Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Remove the hard drive from the device.
结论
3等其他人完成本指南。
一条评论
Be really careful when removing the top case, around the keyboard because there are a couple of really cheap ribbon cables. One connects the power button, another the trackpad. I have to buy a replacement cable and power button board now because I pulled the top case off too quickly and broke the connection at the power button board.
The plastic top case around the keyboard snaps onto the lower part of the case, with many, many tabs and doesn’t even need screws to stay together. You’ll have to wrestle with it, but don’t pull it too far from the lower case.
Warren Buckley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 1,220
