跳转到主内容
HP 15-g010dx Speakers Replacement
你所需要的
  1. HP 15-g010dx Speakers Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g010dx Speakers Replacement: 步骤 2 中的图像 1,1
    • Place your finger on the left latch and slide it towards the center of the laptop.
  3. HP 15-g010dx Speakers Replacement: 步骤 3 中的图像 1,1
    • Pull on the battery to remove.
  4. HP 15-g010dx Speakers Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
  5. HP 15-g010dx Speakers Replacement: 步骤 5 中的图像 1,1
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
  6. HP 15-g010dx Speakers Replacement: 步骤 6 中的图像 1,1
    • Using the tool of your choice, gently pry up on the top of the keyboard.
  7. HP 15-g010dx Speakers Replacement: 步骤 7 中的图像 1,1
    • Release the top of the keyboard.
  8. HP 15-g010dx Speakers Replacement: 步骤 8 中的图像 1,1
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
  9. HP 15-g010dx Speakers Replacement, Speakers: 步骤 9 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the 5 millimeter screws that are visible.
  10. HP 15-g010dx Speakers Replacement: 步骤 10 中的图像 1,2 HP 15-g010dx Speakers Replacement: 步骤 10 中的图像 2,2
    • Using the spudger, remove the two rubber feet that are located near the battery.
  11. HP 15-g010dx Speakers Replacement: 步骤 11 中的图像 1,2 HP 15-g010dx Speakers Replacement: 步骤 11 中的图像 2,2
    • Now remove the two Phillips screws that are located below the rubber feet.
  12. HP 15-g010dx Speakers Replacement: 步骤 12 中的图像 1,3 HP 15-g010dx Speakers Replacement: 步骤 12 中的图像 2,3 HP 15-g010dx Speakers Replacement: 步骤 12 中的图像 3,3
    • Remove the optical drive by pulling it out by hand.
  13. HP 15-g010dx Speakers Replacement: 步骤 13 中的图像 1,1
    • Remove the two Phillips screws inside the optical drive housing.
  14. HP 15-g010dx Speakers Replacement: 步骤 14 中的图像 1,1
    • Disconnect the power button ribbon cable by lifting the connector.
  15. HP 15-g010dx Speakers Replacement: 步骤 15 中的图像 1,3 HP 15-g010dx Speakers Replacement: 步骤 15 中的图像 2,3 HP 15-g010dx Speakers Replacement: 步骤 15 中的图像 3,3
    • Disconnect the touch pad ribbon cable by lifting up on the connector.
  16. HP 15-g010dx Speakers Replacement: 步骤 16 中的图像 1,3 HP 15-g010dx Speakers Replacement: 步骤 16 中的图像 2,3 HP 15-g010dx Speakers Replacement: 步骤 16 中的图像 3,3
    • Now remove the screws indicated by an arrow stamped into the metal, located where the keyboard was.
  17. HP 15-g010dx Speakers Replacement: 步骤 17 中的图像 1,1
    • Take the metal spudger and gently insert in between the palm rest and the body.
  18. HP 15-g010dx Speakers Replacement: 步骤 18 中的图像 1,1
    • Work the spudger in small increments around the palm rest while lifting it up in the air.
  19. HP 15-g010dx Speakers Replacement: 步骤 19 中的图像 1,3 HP 15-g010dx Speakers Replacement: 步骤 19 中的图像 2,3 HP 15-g010dx Speakers Replacement: 步骤 19 中的图像 3,3
    • Carefully remove the palm rest and flip it over.
  20. HP 15-g010dx Speakers Replacement: 步骤 20 中的图像 1,2 HP 15-g010dx Speakers Replacement: 步骤 20 中的图像 2,2
    • Lift up on the speaker connectors to unplug the speaker cables.
  21. HP 15-g010dx Speakers Replacement: 步骤 21 中的图像 1,2 HP 15-g010dx Speakers Replacement: 步骤 21 中的图像 2,2
    • Remove the screws that are securing the speakers.
  22. HP 15-g010dx Speakers Replacement: 步骤 22 中的图像 1,2 HP 15-g010dx Speakers Replacement: 步骤 22 中的图像 2,2
    • Remove the speakers.
终点
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 352
