跳转到主内容
HP 15-g010dx Keyboard Ribbon Cable Replacement
你所需要的
  1. HP 15-g010dx Keyboard Ribbon Cable Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g010dx Keyboard Ribbon Cable Replacement: 步骤 2 中的图像 1,1
    • Place your finger on the left latch and slide it towards the center of the laptop.
  3. HP 15-g010dx Keyboard Ribbon Cable Replacement: 步骤 3 中的图像 1,1
    • Pull on the battery to remove.
  4. HP 15-g010dx Keyboard Ribbon Cable Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
  5. HP 15-g010dx Keyboard Ribbon Cable Replacement: 步骤 5 中的图像 1,1
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
  6. HP 15-g010dx Keyboard Ribbon Cable Replacement: 步骤 6 中的图像 1,1
    • Using the tool of your choice, gently pry up on the top of the keyboard.
  7. HP 15-g010dx Keyboard Ribbon Cable Replacement: 步骤 7 中的图像 1,1
    • Release the top of the keyboard.
  8. HP 15-g010dx Keyboard Ribbon Cable Replacement: 步骤 8 中的图像 1,1
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
  9. HP 15-g010dx Keyboard Ribbon Cable Replacement, Keyboard Ribbon Cable: 步骤 9 中的图像 1,1
    • Gently lift up on the ZIF connector.
  10. HP 15-g010dx Keyboard Ribbon Cable Replacement: 步骤 10 中的图像 1,1
    • Now remove the ribbon cable.
  11. HP 15-g010dx Keyboard Ribbon Cable Replacement: 步骤 11 中的图像 1,1
    • Check for visible damage on the ribbon cable such as folds, kinks, or corrosion.
  12. HP 15-g010dx Keyboard Ribbon Cable Replacement: 步骤 12 中的图像 1,1
    • Using your pencil's eraser, gently clean the contact points on the ribbon cable.
终点
2条评论
my ribbon cable is old, and is not making any good contact, from many times that I have repaired the system, the ribbon cable started not making good contact, because it has inside damage, you know what I mean, it went back and forth many times and it does not want to make good contact, power stops at cable, not board connector
Mitsos Tech Tips - 回复
I’m the same person, if anyone has the same problem and knows a solution just write it down, I’ll reply as soon as possible
HondaCRX -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 61
总计 5,428
