跳转到主内容
加入维修社区 - 创建账户
HP 15-fc0000 Series Speakers Replacement
你所需要的
  1. HP 15-fc0000 Series Speakers Replacement, Power off the laptop: 步骤 1 中的图像 1,1
    • Shut down the laptop.
    • Unplug the charger and any other cables from the laptop.
    询问修复机器人
    添加评论
  2. HP 15-fc0000 Series Speakers Replacement, Remove the bottom cover screws: 步骤 2 中的图像 1,1
    • Close the laptop and flip it over so the rubber feet are facing up. Place the laptop on a soft surface to avoid damaging the top cover.
    • Use a Phillips screwdriver to remove the four screws securing the bottom cover.
    • Two 6.8 mm‑long screws near the rear of the laptop.
    • Two 4.8 mm‑long screws near the front of the laptop.
    询问修复机器人
    添加评论
  3. HP 15-fc0000 Series Speakers Replacement, Release the bottom cover clips: 步骤 3 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Release the bottom cover clips: 步骤 3 中的图像 2,2
    • The clips attached to the bottom cover are fragile. Use caution when releasing them.
    • Insert an opening pick under the bottom cover at the rear of the laptop.
    • Twist the pick until one or more clips release.
    • Repeat this procedure along the rear edge until you release all the clips.
    询问修复机器人
    添加评论
  4. HP 15-fc0000 Series Speakers Replacement: 步骤 4 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement: 步骤 4 中的图像 2,2
    • The bottom cover is fragile. Use caution when bending it.
    • Place your fingers under the part of the bottom cover you've raised, near a corner.
    • Use your fingers to gently pry up the corner of the bottom cover.
    询问修复机器人
    添加评论
  5. HP 15-fc0000 Series Speakers Replacement: 步骤 5 中的图像 1,3 HP 15-fc0000 Series Speakers Replacement: 步骤 5 中的图像 2,3 HP 15-fc0000 Series Speakers Replacement: 步骤 5 中的图像 3,3
    • Insert an opening pick under the edge of the bottom cover next to the corner you've raised.
    • Pry up the back cover clips along the edge.
    询问修复机器人
    添加评论
  6. HP 15-fc0000 Series Speakers Replacement: 步骤 6 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement: 步骤 6 中的图像 2,2
    • Use an opening pick to repeat the procedure from the previous step to pry up the remaining sides of the bottom cover.
    询问修复机器人
    添加评论
  7. HP 15-fc0000 Series Speakers Replacement, Remove the bottom cover: 步骤 7 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Remove the bottom cover: 步骤 7 中的图像 2,2
    • Remove the bottom cover.
    • Some clips may re-engage when you're releasing other sides. If the bottom cover doesn't lift off easily, use the opening pick to release any remaining clips.
    • During reassembly, lay the bottom cover on the laptop so the sides of the cover align with the sides of the laptop. Then, gently press on the sides until you hear the clips click. If the clips don't engage easily, adjust the cover and try again.
    询问修复机器人
    添加评论
  8. HP 15-fc0000 Series Speakers Replacement, Lift the speaker wire tape: 步骤 8 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Lift the speaker wire tape: 步骤 8 中的图像 2,2
    • Do not put too much stress on the wire, as that can harm your laptop's audio quality.
    • Use a spudger or your fingers to lift the tape that adheres the speaker wires to the metal trackpad bracket.
    • Try not to fold the tape so it can be reused during reassembly.
    询问修复机器人
    添加评论
  9. HP 15-fc0000 Series Speakers Replacement, Move the speaker wires: 步骤 9 中的图像 1,3 HP 15-fc0000 Series Speakers Replacement, Move the speaker wires: 步骤 9 中的图像 2,3 HP 15-fc0000 Series Speakers Replacement, Move the speaker wires: 步骤 9 中的图像 3,3
    • Use a spudger or your fingers to remove the speaker wires from the routing clips along the edge of the battery.
    询问修复机器人
    添加评论
  10. HP 15-fc0000 Series Speakers Replacement, Remove the battery screws: 步骤 10 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Remove the battery screws: 步骤 10 中的图像 2,2
    • Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the battery.
    • During reassembly, press firmly on the battery connector to ensure a strong connection.
    询问修复机器人
    添加评论
  11. HP 15-fc0000 Series Speakers Replacement, Remove the battery: 步骤 11 中的图像 1,3 HP 15-fc0000 Series Speakers Replacement, Remove the battery: 步骤 11 中的图像 2,3 HP 15-fc0000 Series Speakers Replacement, Remove the battery: 步骤 11 中的图像 3,3
    • Do not grab the battery at the ends because this battery is flexible. Instead, grab the battery one inch from each end to better support the middle.
    • Use two hands to grip the battery about one inch from each end.
    • Lift the front of the battery (the side closest to you) until the battery is free of its alignment pegs.
    • Pull the battery towards you to release it from its connector.
    • Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
    • During reassembly, insert the battery onto its connector at a slight downward angle before pressing it flat to the frame.
    询问修复机器人
    添加评论
  12. HP 15-fc0000 Series Speakers Replacement, Remove the SSD screw: 步骤 12 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Remove the SSD screw: 步骤 12 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the SSD.
    询问修复机器人
    添加评论
  13. HP 15-fc0000 Series Speakers Replacement, Remove the SSD: 步骤 13 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Remove the SSD: 步骤 13 中的图像 2,2
    • Lift the edge of the SSD near the screw indent to a shallow angle.
    询问修复机器人
    添加评论
  14. HP 15-fc0000 Series Speakers Replacement: 步骤 14 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement: 步骤 14 中的图像 2,2
    • Grip the SSD by its edges and pull it away from its socket to remove it.
    • During reassembly, insert the SSD into its socket at a shallow angle before lowering it flat to the laptop.
    询问修复机器人
    添加评论
  15. HP 15-fc0000 Series Speakers Replacement, Lift the speaker wire tape: 步骤 15 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Lift the speaker wire tape: 步骤 15 中的图像 2,2
    • This tape may still be lifted from an earlier step. If so, skip this step.
    • Use a spudger or your fingers to lift the tape that adheres the speaker wires to the metal touch pad bracket.
    • Try not to fold the tape because it can be reused during reassembly.
    询问修复机器人
    添加评论
  16. HP 15-fc0000 Series Speakers Replacement, Lift the speaker wire: 步骤 16 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Lift the speaker wire: 步骤 16 中的图像 2,2
    • Use a spudger to lift the speaker wire out of the routing clip near the left speaker.
    • The left speaker is on your right, since the laptop is upside down.
    询问修复机器人
    添加评论
  17. HP 15-fc0000 Series Speakers Replacement: 步骤 17 中的图像 1,3 HP 15-fc0000 Series Speakers Replacement: 步骤 17 中的图像 2,3 HP 15-fc0000 Series Speakers Replacement: 步骤 17 中的图像 3,3
    • Repeat the procedure from the previous step to lift the speaker wire out of the two routing clips near the right speaker.
    询问修复机器人
    添加评论
  18. HP 15-fc0000 Series Speakers Replacement, Disconnect the speakers: 步骤 18 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Disconnect the speakers: 步骤 18 中的图像 2,2
    • Insert one arm of blunt nose tweezers under the speaker cable, as close to the connector as possible.
    • Grip the wires evenly and lift the cable up to disconnect the fan.
    • To reconnect the speakers to the motherboard, use a pair of tweezers to grip all of the wires and align the connector with the socket. Then, use the flat end of a spudger or your finger to evenly press the connector into the socket.
    询问修复机器人
    添加评论
  19. HP 15-fc0000 Series Speakers Replacement, Remove the left speaker screws: 步骤 19 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Remove the left speaker screws: 步骤 19 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 3.2 mm‑long screws securing the left speaker.
    • The left speaker is now sitting to your right, since the laptop is upside down.
    询问修复机器人
    添加评论
  20. HP 15-fc0000 Series Speakers Replacement, Remove the left speaker: 步骤 20 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Remove the left speaker: 步骤 20 中的图像 2,2
    • Use your fingers to lift the left speaker off its screw posts and remove it.
    询问修复机器人
    添加评论
  21. HP 15-fc0000 Series Speakers Replacement, Remove the right speaker screws: 步骤 21 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Remove the right speaker screws: 步骤 21 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 3.2 mm‑long screws securing the right speaker.
    询问修复机器人
    添加评论
  22. HP 15-fc0000 Series Speakers Replacement, Remove the right speaker: 步骤 22 中的图像 1,2 HP 15-fc0000 Series Speakers Replacement, Remove the right speaker: 步骤 22 中的图像 2,2
    • Use your fingers to lift the right speaker off its screw posts and remove it.
    询问修复机器人
    添加评论
结论
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
取消:我没有完成这个指南。
Spencer Pennington
于09/09/23注册
25,967 声望
创作了127篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了17,855篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 47
总计 384
