跳转到主内容
加入维修社区 - 创建账户
HP 15-fc0000 Series DC-In Port Replacement
你所需要的
  1. HP 15-fc0000 Series DC-In Port Replacement, Power off the laptop: 步骤 1 中的图像 1,1
    • Shut down the laptop.
    • Unplug the charger and any other cables from the laptop.
  2. HP 15-fc0000 Series DC-In Port Replacement, Remove the bottom cover screws: 步骤 2 中的图像 1,1
    • Close the laptop and flip it over so the rubber feet are facing up. Place the laptop on a soft surface to avoid damaging the top cover.
    • Use a Phillips screwdriver to remove the four screws securing the bottom cover.
    • Two 6.8 mm‑long screws near the rear of the laptop.
    • Two 4.8 mm‑long screws near the front of the laptop.
  3. HP 15-fc0000 Series DC-In Port Replacement, Release the bottom cover clips: 步骤 3 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement, Release the bottom cover clips: 步骤 3 中的图像 2,2
    • The clips attached to the bottom cover are fragile. Use caution when releasing them.
    • Insert an opening pick under the bottom cover at the rear of the laptop.
    • Twist the pick until one or more clips release.
    • Repeat this procedure along the rear edge until you release all the clips.
  4. HP 15-fc0000 Series DC-In Port Replacement: 步骤 4 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement: 步骤 4 中的图像 2,2
    • The bottom cover is fragile. Use caution when bending it.
    • Place your fingers under the part of the bottom cover you've raised, near a corner.
    • Use your fingers to gently pry up the corner of the bottom cover.
  5. HP 15-fc0000 Series DC-In Port Replacement: 步骤 5 中的图像 1,3 HP 15-fc0000 Series DC-In Port Replacement: 步骤 5 中的图像 2,3 HP 15-fc0000 Series DC-In Port Replacement: 步骤 5 中的图像 3,3
    • Insert an opening pick under the edge of the bottom cover next to the corner you've raised.
    • Pry up the back cover clips along the edge.
  6. HP 15-fc0000 Series DC-In Port Replacement: 步骤 6 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement: 步骤 6 中的图像 2,2
    • Use an opening pick to repeat the procedure from the previous step to pry up the remaining sides of the bottom cover.
  7. HP 15-fc0000 Series DC-In Port Replacement, Remove the bottom cover: 步骤 7 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement, Remove the bottom cover: 步骤 7 中的图像 2,2
    • Remove the bottom cover.
    • Some clips may re-engage when you're releasing other sides. If the bottom cover doesn't lift off easily, use the opening pick to release any remaining clips.
    • During reassembly, lay the bottom cover on the laptop so the sides of the cover align with the sides of the laptop. Then, gently press on the sides until you hear the clips click. If the clips don't engage easily, adjust the cover and try again.
  8. HP 15-fc0000 Series DC-In Port Replacement, Lift the speaker wire tape: 步骤 8 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement, Lift the speaker wire tape: 步骤 8 中的图像 2,2
    • Do not put too much stress on the wire, as that can harm your laptop's audio quality.
    • Use a spudger or your fingers to lift the tape that adheres the speaker wires to the metal trackpad bracket.
    • Try not to fold the tape so it can be reused during reassembly.
  9. HP 15-fc0000 Series DC-In Port Replacement, Move the speaker wires: 步骤 9 中的图像 1,3 HP 15-fc0000 Series DC-In Port Replacement, Move the speaker wires: 步骤 9 中的图像 2,3 HP 15-fc0000 Series DC-In Port Replacement, Move the speaker wires: 步骤 9 中的图像 3,3
    • Use a spudger or your fingers to remove the speaker wires from the routing clips along the edge of the battery.
  10. HP 15-fc0000 Series DC-In Port Replacement, Remove the battery screws: 步骤 10 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement, Remove the battery screws: 步骤 10 中的图像 2,2
    • Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the battery.
    • During reassembly, press firmly on the battery connector to ensure a strong connection.
  11. HP 15-fc0000 Series DC-In Port Replacement, Remove the battery: 步骤 11 中的图像 1,3 HP 15-fc0000 Series DC-In Port Replacement, Remove the battery: 步骤 11 中的图像 2,3 HP 15-fc0000 Series DC-In Port Replacement, Remove the battery: 步骤 11 中的图像 3,3
    • Do not grab the battery at the ends because this battery is flexible. Instead, grab the battery one inch from each end to better support the middle.
    • Use two hands to grip the battery about one inch from each end.
    • Lift the front of the battery (the side closest to you) until the battery is free of its alignment pegs.
    • Pull the battery towards you to release it from its connector.
    • Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
    • During reassembly, insert the battery onto its connector at a slight downward angle before pressing it flat to the frame.
  12. HP 15-fc0000 Series DC-In Port Replacement, Remove the right hinge screws: 步骤 12 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement, Remove the right hinge screws: 步骤 12 中的图像 2,2
    • The right hinge is on the left side since the laptop is upside down
    • Use a Phillips screwdriver to remove the three 5.6 mm‑long screws securing the right hinge.
  13. HP 15-fc0000 Series DC-In Port Replacement, Open the right hinge: 步骤 13 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement, Open the right hinge: 步骤 13 中的图像 2,2
    • Lift the left hinge to 90º so it's pointing upward.
  14. HP 15-fc0000 Series DC-In Port Replacement, Disconnect the DC-in cable: 步骤 14 中的图像 1,3 HP 15-fc0000 Series DC-In Port Replacement, Disconnect the DC-in cable: 步骤 14 中的图像 2,3 HP 15-fc0000 Series DC-In Port Replacement, Disconnect the DC-in cable: 步骤 14 中的图像 3,3
    • Use a spudger to "walk" the DC‑in cable out of its socket on the motherboard by pushing on alternating sides of the white connector.
  15. HP 15-fc0000 Series DC-In Port Replacement: 步骤 15 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement: 步骤 15 中的图像 2,2
    • Once the cable it loose, use a spudger to push the DC‑in cable out of its socket on the system board.
  16. HP 15-fc0000 Series DC-In Port Replacement, Lift the DC‑in cable: 步骤 16 中的图像 1,3 HP 15-fc0000 Series DC-In Port Replacement, Lift the DC‑in cable: 步骤 16 中的图像 2,3 HP 15-fc0000 Series DC-In Port Replacement, Lift the DC‑in cable: 步骤 16 中的图像 3,3
    • Use tweezers, a spudger, or fingers to lift the DC‑in cable out of the routing clips beside the fan.
    • During reassembly, make sure the cable is routed through the proper clips.
  17. HP 15-fc0000 Series DC-In Port Replacement, Remove the DC‑in port screw: 步骤 17 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement, Remove the DC‑in port screw: 步骤 17 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3.1 mm‑long screw securing the DC‑in port.
  18. HP 15-fc0000 Series DC-In Port Replacement, Remove the DC-in port: 步骤 18 中的图像 1,2 HP 15-fc0000 Series DC-In Port Replacement, Remove the DC-in port: 步骤 18 中的图像 2,2
    • Use tweezers to pull the DC‑in port away from its slot in the frame to remove it.
结论
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Spencer Pennington
于09/09/23注册
25,732 声望
创作了127篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了17,754篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 58
总计 504
