跳转到主内容
加入维修社区 - 创建账户
HP 15-f033wm Screen Replacement
你所需要的
  1. HP 15-f033wm Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. HP 15-f033wm Screen Replacement: 步骤 2 中的图像 1,2 HP 15-f033wm Screen Replacement: 步骤 2 中的图像 2,2
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. HP 15-f033wm Screen Replacement: 步骤 3 中的图像 1,2 HP 15-f033wm Screen Replacement: 步骤 3 中的图像 2,2
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. HP 15-f033wm Screen Replacement: 步骤 4 中的图像 1,2 HP 15-f033wm Screen Replacement: 步骤 4 中的图像 2,2
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. HP 15-f033wm Screen Replacement: 步骤 5 中的图像 1,3 HP 15-f033wm Screen Replacement: 步骤 5 中的图像 2,3 HP 15-f033wm Screen Replacement: 步骤 5 中的图像 3,3
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
  6. HP 15-f033wm Screen Replacement, Screen: 步骤 6 中的图像 1,1
    • After removing the battery, remove the bezel. Do this by prying it away from the faulty screen using the spudger.
    • Make sure screen is angles as far back as possible to fully remove the bottom hinges of the bezel without damaging the laptop.
  7. HP 15-f033wm Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the four 3 mm PH1 Phillips head screws in each corner of the screen, fastening the screen to the rest of the laptop.
  8. HP 15-f033wm Screen Replacement: 步骤 8 中的图像 1,1
    • Gently remove the screen and place it on the keyboard.
  9. HP 15-f033wm Screen Replacement: 步骤 9 中的图像 1,2 HP 15-f033wm Screen Replacement: 步骤 9 中的图像 2,2
    • Remove the tape on top of the video cable.
    • Gently disconnect the video cable.
结论
4等其他人完成本指南。
Aaron Chabot
于10/17/17注册
629 声望
创作了4篇指南
团队
UMass Dartmouth, Team S1-G4, Simcock Fall 2017 UMass Dartmouth, Team S1-G4, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G4
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 1,710
