跳转到主内容
HP 15-f033wm Battery Replacement
  1. HP 15-f033wm Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. HP 15-f033wm Battery Replacement: 步骤 2 中的图像 1,2 HP 15-f033wm Battery Replacement: 步骤 2 中的图像 2,2
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. HP 15-f033wm Battery Replacement: 步骤 3 中的图像 1,2 HP 15-f033wm Battery Replacement: 步骤 3 中的图像 2,2
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. HP 15-f033wm Battery Replacement: 步骤 4 中的图像 1,2 HP 15-f033wm Battery Replacement: 步骤 4 中的图像 2,2
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. HP 15-f033wm Battery Replacement: 步骤 5 中的图像 1,3 HP 15-f033wm Battery Replacement: 步骤 5 中的图像 2,3 HP 15-f033wm Battery Replacement: 步骤 5 中的图像 3,3
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
结论
2等其他人完成本指南。
Aaron Chabot
于10/17/17注册
620 声望
创作了4篇指南
团队
UMass Dartmouth, Team S1-G4, Simcock Fall 2017 UMass Dartmouth, Team S1-G4, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 797
