简介
Use this guide if your battery in your HP 15-009wm is not working and needs to be replaced. To reduce the risk of electric shock, the battery should be removed before any other repairs are made.
  1. Turn laptop upside down. Flip the lock switch to the unlocked setting.
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Flip the release switch. Once the flip is switched, the battery should pop out. Once the flip is switched, the battery should pop out.
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  4. Slide the battery out. Slide the battery out.
    • Slide the battery out.
结论
Alex Birchler
于2018年02月14日注册
733 信誉积分
创作了5篇指南
团队
USF Tampa, Team S2-G2, Nance Spring 2018 USF Tampa, Team S2-G2, Nance Spring 2018 的会员
USFT-NANCE-S18S2G2
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 99
